Image 6
Specialized Power Arc Pro Saddle
$225.00
The new Power Arc Pro saddle has made improvements on the original Power saddle. Keeping the same channel and length as the original and S-Works Arc. The difference can be found its titanium rails vs. the carbon fiber found on the S-Works. This saddle still has a stiff, FACT carbon fiber shell and lightweight EVA padding. The saddles shape provides plenty of sit bone support, and this has been paired with a shorter-than-usual nose section to keep pressure off of soft tissue while riding in aggressive positions. Designers pushed further via an extra wide and elongated Body Geometry channel that has been test proven to keep blood flow and reduce pressure, reduce numbness and pressure on unwanted areas.
If you already a Power loyalist, this change features a curved Body Geometry shape that contours to your body. What does this mean for your ride? It means that you'll feel as if you're “in the saddle," not on it. And ultimately, this equates to greater comfort and superior performance in all seated positions, whether you're a man or woman.
Geometry Patented Body Geometry design is lab tested for both men and women to assure blood flow to sensitive arteries.
Durability Lightweight, durable, and hollow titanium rails.
Padding Level 2 padding: Medium density foam for bike feel with additional cushioning.
Mounts SWAT™ compatible mounts molded into the saddle base allow for sleek and integrated storage solutions.
Sizes Size 143mm / Weight: 193g Size 155mm / Weight: 199g
