Specialized Phenom Expert Saddle
Article number: | 014-03-02 |
The Phenom Expert was designed for comfort and strength over long days on the road or trail. It features a carbon-reinforced shell with outer-edges that conform to your body for a near-custom fit. This version, unlike the Pro, has rugged titanium rails for lightweight durability, it has our medium density, Level 2 Padding for ample support and comfort. Likewise, at the tail, you'll find the Phenom hallmarks of a rounded, anti-snag design, and throughout the saddle, an expertly-tuned construction that provides the ideal degree of both stiffness and efficiency.
- Patented Body Geometry design is lab-tested to assure blood flow to sensitive arteries.
- Carbon-reinforced shell with flexible Adaptive Edge technology adapts to your body for a custom fit and all-day comfort.
- Low friction panels on the nose and tail improve pedaling efficiency and mobility while moving on and off the saddle.
- Lightweight and durable hollow titanium rails.
- Lightweight and supportive PU foam for increased comfort on longer rides.
- Level 2 padding: Medium density foam for bike feel with additional cushioning.
- SWAT™-compatible mounts molded into the saddle base allow for sleek and integrated storage solutions.
- Size 143mm / Weight 248g
- Size 155mm / Weight 254g
