Sea Sucker Mini Bomber Rack
$440.00
SKU:
SKU-DB890F6F
Two-bike fork-mount rack designed to attach to your car’s roof or trunk, or your SUV’s back glass.
Plastic body flexes to conform to your car’s curves. Four 6” SeaSucker vacuum mounts give this rack plenty of muscle. Includes two 6” Rear Wheel Straps. ¾” black HDPE body for strength and durability. 23”x9” footprint.
Comes with our SeaSucker custom heavy-duty fork mounts, which open wide enough when you release the lever that you don’t have to tighten or loosen the acorn nut on the opposite side every time you put your bike in or take your bike out of the mount.
Holds 2 bikes, up to 45 pounds each, using two fork mount for standard quick release forks.
Specifications:
• Holds 2 bicycles – up to 45 lbs each.
• Made for roof top, trunk or hatchback attachment.
• Attaches to metal, glass or fiberglass surfaces.
• 3/4” thick high-density polyethylene (HDPE) body
• Two heavy-duty fork mounts for 9mm dropouts.
• Four 6″ SeaSucker vacuum cups on body
(210 lb. pull-strength rated each).
• Approx. 27” x 8” footprint.
• Approx. 12 lbs.
What’s in the box:
• Mini Bomber 2-bike rack with standard 9mm fork mounts.
• Two Rear Wheel Straps.
• 5g Lube Tube for vacuum pump maintenance.
• Spare SeaSucker vacuum pad and pump (Spare Tire).
