Sea Sucker Bomber Rack
SeaSucker has taken a novel approach to the rooftop or trunk bicycle rack. For riders without large vehicles or factory roof rack options, insecure trunk style racks or hitch mounts are no longer the only option. Incredibly easy to install and remove, SeaSucker racks are the perfect choice for weekend warriors or anyone looking for convenient bike transporting without installing a permanent rack.
Arguably the quickest and easiest method for mounting up to three bikes on your compact or full size car the Sea Sucker Bomber bike rack offers peace of mind when travelling. The biggest and strongest of the Sea Sucker racks, the bomber features a total of five vacuum cups (each with 210lb pull-strength rating) ensuring your bikes remain secure and safe for the entire journey. Providing a myriad of mounting options the vacuum cups will seal on virtually any smooth non-porous surface, this means it can be mounted on glass, metal, or fiberglass panels. With the absence of hooks or pads found on most other temporary racks, the soft rubber cups ensure no damage will occur to your car’s paint or finish, and are far more secure compared to standard trunk racks. By far the easiest and fastest bike rack to install, SeaSucker racks offer a new world of convenience in bike transportation.
Because of their ease of installation and removal SeaSucker racks should not be left unattended for long periods of time.
Holds 3 bikes, up to 45 pounds each, with a footprint of about 41” x 11”
Some assembly required.
The kit contains the ¾” HDPE body with five vacuum cups already installed
Three heavy duty fork mounts for 9mm drop outs
Three rear wheel vacuum cups with straps
Spare replacement vacuum cup
All the required mounting hardware and owner's manual.
• Holds 3 bicycles – up to 45 lbs each.
• Made for roof top, trunk or hatchback attachment.
• Attaches to metal, glass or fiberglass surfaces.
• 3/4” thick high-density polyethylene (HDPE) body
for strength and durability.
• Three heavy-duty fork mounts for 9mm dropouts.
• Five 6″ SeaSucker vacuum cups on body
(210 lb. pull-strength rated each).
• Approx. 41” x 11” footprint.
• Approx. 14 lbs.
What’s in the box:
• Bomber 3-bike rack with standard 9mm fork mounts.
• Three Rear Wheel Straps.
• 5g Lube Tube for vacuum pump maintenance.
• Spare SeaSucker vacuum pad and pump (Spare Tire)
• Owners Manual
