Schwalbe Pro One Tubeless Tire
$81.00
THE NEXT GENERATION OF TUBELESS TIRES.
A truly thrilling ride. It's fast. It’s reliable. It’s light. The patented MicroSkin construction makes this all possible - 70 g less weight, 15% less rolling resistance and improved cut resistance all around. This is the absolute top model from Schwalbe!
You can also use the Schwalbe Pro One with a normal tube, but its true strengths are experienced only in tubeless form.
SizeISOWeightPressure Range
700 x 25c25-622~275 grams70-110 psi (5.0-7.5 bar)
700 x 28c28-622~320 grams60-95 psi (4.0-6.5 bar)
Compatible Rim Typeclincher
tubeless clincher
Intended Useroad
Tires
Size:
700 x 25
Size:
700 x 28
Style:
Road
