Schwalbe Pro One Addix TLE Tubeless Ready Tire
$72.80
Article number: 006-02-01
A truly thrilling ride. It's fast. It’s reliable. It’s light. The patented MicroSkin construction makes this all possible, ~70g less weight, 15% less rolling resistance and improved cut resistance all around. This is the absolute top model from Schwalbe!
You can also use the Schwalbe Pro One with a normal tube, but its true strengths are experienced only in tubeless form.
Size Weight Pressure Range
 700 x 25c ~245g 70-110 psi (5.0-7.5 bar)
 700 x 28c ~270g 60-95 psi (4.0-6.5 bar)
 700 x 30c ~295g 45-80 psi (3.0-5.5 bar)
 Compatibility Tubeless Clincher
 Intended Use Road
