Schmolke TLO Road Stem
$599.00
Article number: 011-05-03
The Schmolke TLO stem boasts unparalleled performance and durability. Specifically engineered for seamless integration with Schmolke Carbon handlebars, this stem undergoes rigorous testing to ensure optimal performance. Its innovative construction features "loop technology," utilizing carbon fibers wrapping fully around aluminum inserts, which maximize stiffness and minimize noise even at low torque levels. Additionally the TLO stem comes with holes on the underside of the stem to allow for the option of running internal cable routing (ICR).
Crafted with precision and premium materials, the Schmolke TLO stem not only enhances the aesthetic appeal of any road bike but also guarantees a pleasurable riding experience.
 Length 80 mm 100 mm 110 mm 120 mm
 Weight ~ 80g ~ 89g ~ 91g N / A
 Stem Angle -6°
 Stack 40 mm
 Clamp Diameter 31.8 mm
 Steerer Diameter 1 - 1/8" (1.125mm)
 Max Torque 4Nm
 Rider Weight Limit 243 lbs (110 kg)
 Recommended Use Road only
 Material Stem Hardware
  Carbon Fiber Steel / Aluminum / Titanium
