Schmolke Fullover Road Handlebar
$540.00
Almost every component and aspect of the bicycle has moved towards large diameter thinner walled construction to keep weight down and improve stiffness. The handle bar is one exception, despite two increases in clamp diameter the contact point for bars has never seen a major change from the standard 24mm diameter. That is until now. Schmolke, the first to build a carbon handlebar, is also the first company to apply a wider diameter to the full width of a handlebar. It's a small 3.5mm increase, bringing the diameter to 27.5mm, but the increase in stiffness and feel is significant. Sprinters will enjoy the extra stiffness as the most noticable increase is the furthest from the clamp, in the drops. Also, the geometry, based on the compact carbon bar, is perfect for sprinting with its short upper reach clearing room for your hands.
Compact Design
Schmolke's compact handlebar design follows an industry trend that increases the utility of the road handlebar by creating more useful hand positions and shortening lever reach from the drops. This design raises the brake hoods, creating a smooth, flat transition from the climbing position. This oversized edition features increased stem clamp diameter to match the current industry standard 31.8 mm, as well as an oversize oval top section for improved comfort and aerodynamics. These increased diameters create a much stiffer handlebar with only a slight weight penalty.
Shifter Clamps / Weight
The FullOver includes its own shifter clamps since no shifter clamp is compatible with the larger 27.5 diameter. The clamps, not included in the standard Compact bar, save about 18 grams compared to stock clamps found on Campagnolo, Sram and Shimano shifters. When compared side by side this puts the FullOver TLO around 5 grams lighter than the original compact TLO.
The Lightest One (TLO) vs Super Light (SL)
The Lightest One (TLO) is Schmolke's lightest line of products, they're made the with highest quality carbon fibre and take advantage of years of carbon fibre manufacturing knowledge to create some of the lightest components in the industry. The TLO line, as with all extremely light components, takes a level of maintenance beyond a normal "bolt it and forget about it" approach. Carbon assembly paste and torque wrenches are an absolute must, as is regular cleaning and inspection. The Super Light (sl) line is Schmolke's second lightest line of components and is ideal for more powerful riders that want a stable platform to sprint and climb on. is meant for riders that are looking for Schmolke quality but are okay with a
Carbon assembly paste is included with each Schmolke handlebar, and it is highly recommended that this paste be used to increase the security of the stem clamp and reduce the necessary bolt torque. Additionally, Schmolke only recommends use of four-bolt faceplate stems with their carbon handlebars. Please note that these versions of the TLO handlebar are not compatible with clip on aerobars, which require reinforcement in the carbon structure.
Stem Clamp Diameter 31.8 mm
Width* 46 cm
Weight
TLO ~163 grams
SL ~182 grams
Rider Weight Limit
TLO 75 kg (165 lbs)
Geometry
Reach 95 mm
Drop 138 mm
Product Manuals
*measured outside to outside
