Schmolke Carbon Bolts (M6 x 40mm - Hex Head)
Article number: | 017-05-01 |
Schmolke carbon bolts are perfect for shaving weight here and there. These M6 x 40 mm countersunk bolts fit many common headset top caps, allowing you to properly preset the load on your headset while shedding a little weight.
Sold Individually
Bolt Material | Carbon |
Weight (pair) | ~1.5 grams |
Bolt Length | 40mm |
