Pulse OS Rim Bed
Pulse Non Offset Rim bed
Ryde Pulse Comp Rim
$135.00 $65.00
(You save $70.00)
With their cycling roots stretching back over a century Ryde is no stranger to the finesse required to succeed in the industry. Started in 1923 as Van Schothorst in the Netherlands, Ryde began to make a name for themselves with their light yet durable rims. In 1989 they acquired the venerable rim manufacturer Rigida (Founded in 1908), adding a plethora of history and technique to their already respectable history. From the start Ryde has been crafting rims specifically for cyclists with an eye for precision.
The Pulse Comp rim is the perfect subtle yet trustworthy all around option. A fully tubeless compatible rim with optimized rim well and bead hooks, this rim will be a hit with enthusiasts and racers alike. The unique anodising is a dark matte charcoal color. Unlike highly polished rims that have a glossy finish after anodising, the Pulse rims have a soft muted hue that doesn’t reflect light.This unassuming look is contrasted by the brilliantly eye catching decals, but if you’re chasing that illusive stealthy look the decals can easily be removed. The asymmetric front and rear design allows Ryde to tailor the rims to meet specific criteria, without needless added weight. The rear rim features an Offset design that allows for more even spoke tension. This is especially crucial as hub flanges have been pushed inward to accommodate 11 speed drivetrains. Receiving Ryde’s Internal Dimpling process during manufacturing to alleviate spoke fatigue at the nipple, the Pulse Comp will provide every rider with a dependable and steadfast wheel for countless miles. For riders in search of an aluminum clincher rim that is light enough to pedal all day, while simultaneously possessing the durability to withstand the abuse of the toughest rides, the Pulse Comp is the perfect choice.
Please note that Symmetrical rims are designed for front wheel use while Offset rims are intended to be used for rear wheel builds.
Weight430 grams
Internal Rim Width 17.8mm
External Rim Width22.2mm
Rim Depth24.9mm
ERD Symmetrical Rim585mm
ERD Offset Rim587mm
Recommended Tire Size23-30mm
