Redshift Shockstop Stem
The ShockStop Stem offers a sleek suspension solution for road, gravel, and e-bikes. Made from 6061-T6 aluminum, it features an adjustable elastomer system for up to 20mm of travel. Available in 80-120mm lengths and weighing 256-302g, it comes in +/-6° and +30° options, with the oversized 1-1/4" steerer available only in the +/-6° configuration. Five elastomers allow fine-tuning for different terrains. Paired with the ShockStop Suspension Seatpost, it enhances control and comfort without sacrificing handling. Ideal for long rides, technical trails, or daily commutes, it’s a smart upgrade for any bike.
- Unwanted vertical movement is absorbed by twin interchangeable elastomers
- Stem retains torsional rigidity
- Effective suspension travel: - Up to 20mm
- Includes 5 swappable elastomers (2 pre-installed, 3 additional) to customize the ride feel for your bike, weight, and riding style
80 mm | 90 mm | 100 mm | 110 mm | 120 mm | |
Weight | ~256g | ~266g | ~278g | ~290g | ~302g |
Stem Angle | |||||
+/- 6° | +/- 6° / +30° | +/- 6° | +/- 6° / +30° | +/- 6° | +/- 6° |
+30° | +/- 6° / +30° | N / A | +/- 6° / +30° | N / A | N / A |
Clamp Diameter | 31.8 mm | ||||
Steerer Clamp Diameter | 1-1/8" (28.6 mm) | *1-1/4 (31.8mm) | ||||
Stack Height | 40 mm | ||||
Material | 6061-T6 Aluminum | ||||
Rider Weight Limit | 135 kg (300 lbs.) | ||||
1 - 1/4" ONLY comes in +/- 6° |
