RaceFace Next SL Carbon Mountain Crankset
$430.00 $325.00
(You save $105.00)
Introducing the Next SL mountain bike crank from RaceFace. These are Canadian-manufactured from American-sourced carbon and aluminum. Due to RaceFace's proven hollow crank arm technology, these have jumped right into the fray as one of the lightest production cranksets out there, on par with THM Clavicula mountain cranks. The Next SL cranks are designed to withstand a lot of abuse, and are rated for use in XC race, trail, and enduro style riding.
Unlike many other crank manufacturers that claim to produce cranks with full carbon arms, the Next SL crankarms are completely hollow, without using an aluminum spine running the length of the arm.
The Next SL also takes advantage of Race Face's own proprietary spider and chainring interface called the "Cinch" system. Essentially the chainring or spider is held on by a lockring that can be removed with a conventional Shimano-type splined BB tool such as the Park #BBT-22. This means that the Cinch system is extremely secure, while allowing for easy reconfiguration to different chainring counts.
As if the Next SL crankset wasn't innovative enough as is, it also debuts the Race Face "Narrow Wide" chainrings. As the name entails, these employ chainring teeth with a narrow to wide profile, with teeth specific to the male or female parts of your chain, making them the perfect component choice for everything from single speed to 1 x 9, 10, or 11 speed applications.
RaceFace's Cinch system is designed to be incredibly modular. As such, you will have to select among the following options to complete your Next SL crankset. When ordered with a crankarm set, spiders and chainrings will be professionally installed prior to shipment.
Weight, 175 mm365 grams
Materialcarbon, "super alloy" aluminum
Spindle Diameter30 mm
Available Lengths170, 175 mm
Compatible BBsSee BB chart
ApplicationAll Mountain, Enduro, Downhill
Product Manuals
Cinch System Installation
