Race Face Cinch Bottom Brackets
$60.00
If you need a durable, long wearing bottom bracket, consider this offering from RaceFace. They come factory filled with Phil Wood grease for smooth operation. The crank spindle is supported by standard 6806 bearings. The whole assembly is sealed from the elements by an internal liner. Suitable for use in XC/AM/FR/DH.
In order to install the RaceFace BSA bottom bracket that accommodates a 30 mm crank spindle, RaceFace's own Cinch Bottom Bracket Wrench must be used. To avoid frame damage, we recommend the press fit bottom brackets be professionally installed using a proper bearing press.
BB Shell68mm/73mm
Axle Diameter30mm
Bearings6806
Weight92g
Product Manuals
Cinch System Bottom Bracket Compatibility Chart
BB92/89.5/104.5/107 Installation Guide
BSA 30 Thread Installation Guide
PF30 Installation Guide
Cinch System Installation Guide
