Pro Gold Chain Lube
$9.50
Article number: 005-01-02
ProLink Chain Lube will not let dirt and grit stick to your chain – in wet or dry conditions. It greatly reduces friction and wear, allowing smoother operation of your chain and cables, and it will keep your chain and drive train area clean and seemingly drag free. ProLink is a thin-bodied lubricant that uses MFR technology, a molecule which bonds to the metal surface. It does not build up or become tacky because it contains no solids like Teflon, wax, moly, graphite or plastic.
The Xtreme version is formulated for any weather and any terrain. Combining metal friction reducer technology with more persistent carriers. Xtreme is a chain lube formula for long-distance and extreme off-road conditions. MFR bonds to metal surfaces and resists build-up and tackiness, in addition to shedding water.
