Praxis Zayante Gravel Carbon Crankset
$350.00
Article number: 024-02-00
The Praxis Zayante Carbon Gravel crankset, with carbon arms and an M30 alloy spindle, offers lightweight, durable performance for gravel. It's compatible with Shimano GRX and SRAM "Wide" 2x front derailleurs, featuring a 47mm chainline and 48/32 LevaTime II X-Rings. The 1x setup option maintains a 48mm chainline. Weighing 605 grams, it has a 150mm Q-factor and fits various bottom brackets. It's suitable for 10-12 speed chains and ensures easy installation with an 8mm self-extracting bolt.
 Crankarms 165 mm 170 mm 172.5 mm
 Weight ~400g ~405g ~409g
 Chainrings 48 / 32
 Weight ~196g
 Q-Factor 150 mm
 Chainline 47 mm
 Bottom Bracket Praxis M30 Bottom Bracket
 Chain   Compatibility 10 / 11 / 12 Speed - Shimano, KMC, SRAM (Flattop Included)
 Spindle M30 (30 mm Drive / 28mm Non-Drive Side)
 Material ARMS - Carbon Fiber | CHAINRINGS / SPIDER - Aluminum
 Interface/BCD SRAM (Praxis) 3-Bolt Style / 160 BCD
 Chainring   Options 2x - 48 / 32 1x - Any SRAM Style DM
