Praxis Zayante Carbon-S Crankset
Article number: | 015 |
The Praxis Zayante Carbon-S crankset captures the essence of Northern California's renowned climbs, combining lightweight performance with efficient power transfer. With carbon arms and streamlined LevaTime II Aluminum chainrings, this version pays tribute to the cycling history of the Northern California Coast and Santa Cruz Mountains. Named after the iconic Zayante climb, it serves as a nod to the region's rich road riding heritage. The S-Version comes equipped with economically designed LevaTime II rings featuring steel bolts.
Crankarms | 165 mm | 170 mm | 172.5 mm | 175 mm |
Weight | ~400g | ~405g | ~408g | ~410g |
Chainrings | 48t / 32t | 50t / 34t | 52t / 36t | |
Weight | ~199g | ~210g | ~224g | |
Drivetrain | (*) 2 X | 1 X | ||
Chainline | (*) 44.5 mm | 45.5 mm | ||
Chainring Options | 48 / 32, 50 / 34, 52 / 36, 53 / 39 | Any SRAM Style DM | ||
Q-Factor | 147 mm | |||
Bottom Bracket | Praxis M30 | |||
Spindle | M30 - 30 mm (Drive-Side) / 28 mm (Non-Drive-Side) | |||
Chain Compatibility | 10 / 11 / 12 - Shimano, KMC, Campagnolo, SRAM (Flattop Included) | |||
Material | ARMS- Carbon Fiber | CHAINRINGS / SPIDER- Aluminum | |||
Interface/BCD | SRAM (Praxis) 3-Bolt Style / 160 BCD | |||
(*)2x - Not Compatible with GRX Front Derailleurs |
