Praxis Zayante Carbon-S Crankset
$275.00
Article number: 024-03-00
The Praxis Zayante Carbon-S crankset captures the essence of Northern California's renowned climbs, combining lightweight performance with efficient power transfer. With carbon arms and streamlined LevaTime II Aluminum chainrings, this version pays tribute to the cycling history of the Northern California Coast and Santa Cruz Mountains. Named after the iconic Zayante climb, it serves as a nod to the region's rich road riding heritage. The S-Version comes equipped with economically designed LevaTime II rings featuring steel bolts.
 Crankarms 165 mm 170 mm 172.5 mm 175 mm
 Weight ~400g ~405g ~408g ~410g
 Chainrings 48t / 32t 50t / 34t 52t / 36t
 Weight ~199g ~210g ~224g
 Drivetrain (*) 2 X 1 X
 Chainline (*) 44.5 mm 45.5 mm
 Chainring Options 48 / 32, 50 / 34, 52 / 36, 53 / 39 Any SRAM Style DM
 Q-Factor 147 mm
 Bottom Bracket Praxis M30
 Spindle M30 - 30 mm (Drive-Side) / 28 mm (Non-Drive-Side)
 Chain Compatibility 10 / 11 / 12 - Shimano, KMC, Campagnolo, SRAM (Flattop Included)
 Material ARMS- Carbon Fiber | CHAINRINGS / SPIDER- Aluminum
 Interface/BCD SRAM (Praxis) 3-Bolt Style / 160 BCD
(*)2x - Not Compatible with GRX Front Derailleurs
