Praxis Zayante Carbon Crankset
$325.00 $276.25
(You save $48.75)
The Zayante Carbon crankset is the next evolution of Praxis Cycles' Zayante M30 platform. The move from aluminum to carbon crank arms shaves about 70 grams from the Zayante platform, yielding a crankset with an excellent balance of features for the best possible performance. With a plethora of premium bottom bracket options and the addition of direct-mount splines and Praxis' all-new X-Spider and X-Ring options, this crankset proves even more versatile than its aluminum predecessor. The Zayante Carbon can pull its weight on a wide range of bicycles, from adventure and gravel rigs to road and triathlon race machines.
Praxis' X-Spider proprietary chainring interface maximizes drivetrain stiffness for faster shifts and the best possible power transfer. Using a unique 4-bolt 160/104 BCD, Praxis is able to fit four double chainring options on the same spider for maximum convenience and versatility. These chainrings are cold forged for strength, durability, and long wear life. They share the same LevaTime I profile as Praxis' popular Buzz chainring series for the best possible shifting on both 10 and 11 speed drivetrains, with excellent performance on mechanical and electronic drivetrains.
Praxis Works warrants components to be free from defects in materials or workmanship for a period of 2 years after original purchase. For more details, see their warranty page.
Ordering
The Zayante Carbon is available in standard crank lengths: 170, 172.5, and 175mm. The 30/28mm stepped M30 aluminum spindle is compatible with nearly all existing road bottom bracket standards, and quality of Praxis' legendary bottom brackets speak for themselves. The Zayante Carbon is available with Praxis' proprietary X-Ring design with four separate double chainring options, including a 48/32 sub-compact option ideal for gravel bikes and specialist climbers. This crankset may also be purchased wtih a single Wave Tech chainring in 38, 40, or 42 tooth. With its 3-bolt Sram-style direct mount splines, the driveside crankarm is totally modular and can be converted at will between single and double ring configurations. Additionally, the Zayante Carbon M30 crankset is fully compatible with SRM and Power2Max power meter chainring spiders.
Product Video
Weight, Crankarms Only425 grams
Weight, 1x (42t)510 grams
Weight, 2x (52/36)635 grams
Spindle Diameter30/28mm
Q-Factor147mm
Chainring BCD160/104
Chainring Spider MountSram/Truvative 3-bolt Direct Mount
Crankarm Materialcarbon fiber
Spindle Materialaluminum
BB OptionsBSA, BB30/PF30, BB386 EVO, BB86, BBRight, T47 Internal, T47 External(68/73mm)
Chainring OptionsDouble - 53/39, 52/36, 50/34, 48/32
Single - 42, 40, 38
Drivetrain Compatibility10/11 speed, mechanical & electronic
