Praxis Zayante Carbon Crankset
$350.00
Article number: 015
The Praxis Zayante Carbon crankset elevates your ride with its featherlight carbon fiber arms and advanced Levatime II chainrings. This innovative crankset pairs extreme lightweight performance with unbeatable power transfer efficiency to give you a true competitive edge. The patented Levatime technology delivers a smoother pedal stroke while the carbon fiber arms provide uncompromising stiffness to channel all your watts into forward motion. Experience the game-changing performance of Praxis's lightest, stiffest crankset yet. Praxis is dedicated to pushing the boundaries of cycling technology without pushing your budget.
 Crankarms 165 mm 170 mm 172.5 mm 175 mm
 Weight ~400g ~405g ~408g ~410g
 Chainrings 48t / 32t 50t / 34t 52t / 36t 53t / 39t
 Weight ~195g ~202g ~211g ~216g
 Drivetrains 2 X 1 X
 Chainline (*)44.5 mm 45.5 mm
 Chainring Options 48 / 32, 50 / 34, 52 / 36, 53 / 39 Any SRAM Style DM
 Q-Factor 147 mm
 Bottom Bracket Praxis M30
 Spindle M30 - 30 mm (Drive-Side) / 28 mm (Non-Drive-Side)
 Chain Compatibility 10 / 11 / 12 - Shimano, KMC, Campagnolo, SRAM (Flattop Included)
 Material ARMS- Carbon Fiber | CHAINRINGS / SPIDER- Aluminum
 Interface/BCD SRAM (Praxis) 3-Bolt Style / 160 BCD
(*)2x - Not Compatible with GRX Front Derailleurs
