Breaking into the cycling market in 2011, Praxis Works has become well known for their high quality chainrings. Their attention to detail and meticulous construction has allowed them to produce chainrings that perform on par or better than virtually every other chainring on the market. Continually improving their designs and features, these new mountain rings feature the Wave tooth profile developed by MRP. This new unique tooth profiling has similar chain retention properties to Narrow Wide chainrings, but with the alternating contact faces allows for more mud and debris shedding while also removing a bit of excess material. These 4.5mm thick rings offer optimal stiffness for aggressive riding while remaining in XC class weight ranges. Durability is unsurpassed thanks to Cold Forging and Hard Anodizing processes performed on each ring.
For flawless performance even under the most demanding conditions pair your Wave chainring with one of Praxis Works Chain Guides for ideal chain retention.
Shipping: Due to restrictions from International distributors we are not allowed to ship Praixs products to addresses in the following countries:
Australia, Austria, Belgium, Canada, China, Czech Republic, Denmark, Finland, France, Germany, Italy, Japan, Liechtenstein, Luxembourg, Malaysia, Netherlands, New Zealand, Norway, Portugal, Singapore, Slovakia, Spain, South Africa, Sweden, Switzerland, UK.
Material | Hard Anodized 7075-T6 Aluminum |
Crank Compatibility | 4 Arm 94 BCD 4 Arm 104 BCD |
Chain Compatibility | Shimano 10/11 SRAM 10/11 KMC 10/11 |
Rear Derailleur Compatibility | Requires Clutch Type Derailleur. I.E. Shimano Shadow Plus or SRAM Type 2 |
Weights | |
94 BCD - 30T | 30.5 grams |
104 BCD - 30T | 35 grams |
104 BCD - 32T | 34 grams |
104 BCD - 34T | 51 grams |
104 BCD - 36T | 64 grams |
