Praxis Wave 1x 104 BCD Mountain Chainring
Article number: | 015-02-02 |
The Praxis Works Wave 4 x 104 BCD single chainring advances the narrow-wide concept with its unique design. By applying alternating lateral force to each chain link, it enhances chain retention without compromising mud shedding. Compared to traditional narrow-wide rings, it reduces friction, optimizing performance across wide gear ranges. Available in multiple tooth counts, this chainring fits 4 x 104 BCD cranks, making it compatible with various setups. Its precise chainline options ensure optimal alignment, whether using a Praxis crank or another brand. For superior chain security in all conditions, the Praxis Works Wave chainring is the perfect choice.
Please select your chainring according to your crank and frame style. If you have questions please contact us and we will assist you in selecting the optimal ring for your needs.
Material | CNC Machined 7075-T6 Aluminum Hard Blk Anodized | |||
Recommended Rear Derailleur | Requires Clutch Type Derailleur Shimano or SRAM | |||
Crank Compatibility | 4-bolt x 104 BCD spider | |||
Chain / Drivetrain Compatibility | 10 / 11 / 12 Speed - Shimano, SRAM, KMC | |||
30t | 32t | 34t | 36t | |
Weight | ~31g | ~35g | ~38g | ~40g |
