Praxis Wave 1X Direct Mount Road/Gravel/CX Chainring
$85.00
$59.50
* Unit price: $59.50 /
Article number: 025-05-01
With its Wave format, the Praxis Works single chainring actively retains the chain using alternating lateral force on each link. This allows space to shed mud and debris while reducing friction compared to traditional narrow wide rings, especially when running less than optimal chain lines. As drivetrain gear counts increase and wider tires push chains and chainrings to their limits, the Wave’s advantages stand out. Its mud-shedding abilities keep your drivetrain running smoothly through the gnarliest conditions. The Praxis Works Wave chainring brings next-level performance to single speed systems.
Please select your chainring according to your crank and frame style. If you have questions please contact us and we will assist you in selecting the optimal ring for your needs.
All Direct Mount Road / Gravel / CX chainrings are Not Compatible with Campagnolo 11 / 12 / 13 Speed chains.
Chainline
45.5 mm | 48 mm (Gravel Cranks)
Recommended Rear Derailleur
Clutch Type Derailleur Shimano / SRAM / Upper Chain Guide
Weights
36t ~92g 38t ~96g 40t ~99g
42t ~112g 44t ~151g 46t ~155g
48t ~166g 50t ~171g
