Praxis Wave 1X Direct Mount MTB Chainring
Article number: | 025-05-01 |
The Wave single chainring from Praxis Works takes the narrow-wide concept to the next level. Alternating lateral force on each chain link actively grips the chain without sacrificing mud shedding. Less friction compared to traditional narrow wide rings optimizes shifting across wide gear ranges. Available in a broad range of tooth counts, these rings pair with Praxis Works Cadet cranks or any 3-bolt SRAM style crank. Two chainline options mean dialing in precise alignment, whether using a Praxis crank or another brand. For unrivaled chain security without sacrificing all-conditions performance, the Praxis Works Wave chainring delivers.
Please select your chainring according to your crank and frame style. If you have questions please contact us and we will assist you in selecting the optimal ring for your needs.
Material | CNC Machined 7075-T6 Aluminum Hard Blk Anodized | ||||
Recommended Rear Derailleur | Requires Clutch Type Derailleur Shimano Shadow Plus or SRAM Type 2 | ||||
Crank Compatibility | Praxis Direct Mount crank or SRAM 3-Bolt Direct Mount style | ||||
Chain / Drivetrain Compatibility | 10 / 11 / 12 Speed - Shimano, SRAM, KMC | ||||
Weights / Chain line Offset | DMA / 3 mm | DMB / 0 mm | |||
30t | ~60g | ~58g | |||
32t | ~64g | ~62g | |||
34t | ~69g | ~67g | |||
36t | ~77g | ~75g |
SHIPPING
Due to restrictions from International distributors we are not allowed to ship Praxis products to addresses in the following countries: Australia, Austria, Belgium, Canada, China, Czech Republic, Denmark, Finland, France, Germany, Italy, Japan, Liechtenstein, Luxembourg, Malaysia, Netherlands, New Zealand, Norway, Portugal, Singapore, Slovakia, Spain, South Africa, Sweden, Switzerland, UK.
