Praxis Shimano Bottom Bracket
| Article number: | 015-04-02 |
Unleash the potential of your ride with Praxis Works' forged durable bottom brackets. Prioritizing longevity, their Shimano Bottom Bracket guarantees smooth rides. Whether upgrading or replacing, Praxis ensures miles of friction-free spinning and unparalleled peace of mind. Compatibility: 24mm spindle.
The PF30/BB30 variant comes with a sleeve for PF30 frames. Press fit the sleeve before threading in the BB30 converter. For BB30 frames, discard the sleeve and install the BB30 adaptor. The versatile design allows wires to pass over the BB shell, with weight-saving holes (not for wire routing). Protect your wiring if used as a last resort.
| BB Compatibility | ||
| Fitment | Weight | Bracket Width |
| BSA 68 / 73 (English Thread) | ~98g | 68 / 73 mm |
| BB30 / PF30 - 68 / 73 mm | ~130g / ~140g | 68 / 73 mm |
| T47 Internal | ~104g | 85.5 mm |
| T47 External | ~104g | 68 / 73 mm |
| Crank Compatibility | ||
| Shimano Hollowtech II | ||
| Bearings | ||
| 24 mm Drive / 24 mm Non-Drive | ||
| 2 - 2437 - Cartridge Steel or Ceramic | ||
| Tools / Installation | ||
| The T47 Internal uses the T47 I.B. tool | ||
| All others use a 44 mm ID socket tool | ||
