Praxis Road / CX 5-bolt Chainring Set
Article number: | 015 |
The Buzz chainring set from Praxis delivers improved aesthetics and compatibility while maintaining the exceptional performance that has made Praxis a leader in drivetrain technology. Forged from durable 7075 aluminum and equipped with LevaTime ramps and pins for lightning-fast shifting, these chainrings carry on the Praxis legacy of strength, precision engineering, and race-tested innovation. The updated hidden bolt design broadens crankset compatibility. Whether you're looking to upgrade your existing setup or build a new dream bike from the frame up, the Buzz chainring set offers optimized shifting and power transfer to help you get the most out of every ride.
These chainrings are sold in matched sets for either compact 110 BCD or standard 130 BCD cranksets. Chainrings do not include chainring bolts.
*Please Note: The 48/32 chainring combination is only compatible with Praxis' 110 BCD cranksets, which have specially-designed chainring mounting tabs. This chainring set includes a set of custom chainring bolts required for installation.
Install Praxis chainrings by aligning a pin hole with the crank, using the long or short pin as fits. Insert pin, grease, and mount with chainring bolts, applying grease to threads and interfaces for smooth operation.
BUZZ | ||||
Fits | 48t / 32t | 50t / 34t | 52t / 36t | 53t / 39t |
Weight | ~150g | ~153g | ~158g | ~163g |
BUZZ SPORT | ||||
Fits | 48t / 32t | 50t / 34t | 52t / 36t | |
Weight | ~192g | ~191g | ~198g | |
Crank Compatibility | 5-bolt 110 BCD* | 5-bolt 110 BCD | 5-bolt 130 BCD | |
Material | Cold Forged 7075-T6 Aluminum | |||
Chain Compatibility | Shimano - Campagnolo - SRAM - KMC - 10 / 11 / 12 Spd | |||
Drivetrain Compatibility | Eletronic & Mechanical | |||
* Only for Praxis 110 BCD cranks |
