Praxis Replacement Bolt / Extractor
$15.00
Article number: 024-03-01
The Praxis M30 or M24 Main Bolt & Self-Extractor kits keep your crank arms spinning smoothly for the long haul. These all-in-one solution combine a durable chromoly steel main bolt with an integrated self-extractor. Simply use an 8mm hex wrench to install the bolt and securely fasten your M30 or M24 crank arm. When service is needed, the self-extractor design allows easy crank arm removal using a cassette tool.
 Crankarms M30 M24
 Bolt Size M16 x 1.0 x 16 mm M15 x 1.0 x 15 mm
 Usage Praxis M30 & SL eCranks Praxis M24 & eCranks
 Torque 48 - 52Nm
 Tools 8 mm Allen
