10% Off all 3T Components!
Praxis Narrow Wide Chainring
Sign Up For Our Newsletter
You're Signed Up!
Material7075 T6 Aluminum
Drivetrain Compatibility10spd, 11spd
Derailleur Compatibility'CLUTCH' type rear derailleur.
I.E. Shimano Shadow or SRAM Type 2
BCD104
Compatible Chainring bolts (30t)Wolf Tooth 10mm Chainring Bolts
Weight
30t *36g
32t41g
34t51g
36t63g
38t73g
Praxis Narrow Wide Chainring 30 tooth $75.00 Notify Me When Available
Praxis Narrow Wide Chainring 32 Tooth $50.00  1 Remaining
Praxis Narrow Wide Chainring 34 Tooth $50.00  1 Remaining
Praxis Narrow Wide Chainring 36 Tooth $55.00  1 Remaining
Praxis Narrow Wide Chainring 38 Tooth $55.00  1 Remaining
Details
In early 2011 Praxis started to make a name for themselves in the bicycle industry though their expertly manufactored chainrings. Their Cold Forge process and attention to detail produced an after market chainring that no cyclist had experienced before leading to the intial popularity of the brand. Now their chainring offerings have continued to expand into niches of the community that are looking for high quality performance parts. In this vein we're happy to offer Praxis' single speed narrow wide chainring to you. The chain retention is high quality and potentially noticably better than some other offerings on the market. Weight is very competitive and their Cold Forge process ensures that you will have a chain ring that will not only last for years of heavy abuse but provide a worry free experience even in the steepest rock gardens.
*Please take notice that the 30 tooth chainring requires chainring bolts with an 8 mm thread diameter, and at least 7 mm of threads in length. For your convenience we've listed the dimensions of each chainring bolt set we sell.
