Praxis N/W Alloy 1X 104 BCD MTB Chainring
$50.00
With Praxis' updated MTB 4x104 BCD Narrow/Wide chainrings, Praxis Works brings the renowned chain retention and mud shedding abilities of this design to wider range 1x drivetrains. Forged and machined from durable 7075-T6 aluminum then hard anodized, these lightweight rings are built to withstand the demands of enduro, downhill, and cross-country riding. Alternating narrow and wide tooth profiles actively grip chains, while efficient open spaces prevent packing between links. Available in 32T, 34T and 36T sizes, the MTB 4x104 BCD chainrings deliver optimized gearing for modern 1x mountain bikes. As leaders in drivetrain technology, Praxis creates exceptional products to enhance the cycling experience.
Recommended Rear Derailleur
Requires Clutch Type Derailleur Shim. Shadow or SRAM Type 2
Weights
32t 34t 36t
~35g ~40g ~46g
___________________________: ____________________________
Interface / BCD: • 4-Bolt 104 BCD
Chain Compatibility: • 10 / 11 / 12 Speed - Shimano, KMC, Campagnolo, SRAM (Flattop Inlcuded)
Material: • High Grade 7000 series alloy | Hard Black Anodized
Drivetrain: • 10 / 11 / 12 Speed - Shimano, SRAM (FlatTop) | Mechanical & Electronic
