Praxis N/W Steel 1X 104 BCD MTB E-Ring Chainring
Praxis' MTB E-Rings, crafted from case-hardened steel, are built for e-MTB durability. With a narrow/wide tooth design, they ensure chain retention and are compatible with 104 BCD e-MTB spiders and M8 bolts. Suitable for 10-12 speed Shimano, SRAM, and KMC drivetrains, they come in 32T, 34T, and 36T sizes. The black oxide finish guarantees lasting off-road performance.
Material | ||||
Cold Forged | High Grade 4130 grade steel | Black Oxide finish | ||||
Recommended Rear Derailleur | ||||
Requires Clutch Type Derailleur Shim. Shadow or SRAM Type 2 | ||||
Crank Compatibility | ||||
4-bolt 104 BCD crank | ||||
Chain Compatibility | ||||
10 / 11 / 12 Speed - Shimano, SRAM, KMC | ||||
Drivetrain Compatibility | ||||
Shimano / SRAM mechanical and electronic | ||||
Weights | ||||
32t | 34t | 36t | ||
~98g | ~105g | ~116g | ||
*E-Rings are threaded, need M8 x 7.5 mm bolt |
SHIPPING
Due to restrictions from International distributors we are not allowed to ship Praxis products to addresses in the following countries: Australia, Austria, Belgium, Canada, China, Czech Republic, Denmark, Finland, France, Germany, Italy, Japan, Liechtenstein, Luxembourg, Malaysia, Netherlands, New Zealand, Norway, Portugal, Singapore, Slovakia, Spain, South Africa, Sweden, Switzerland, UK.
