Praxis N/W 1X Direct Mount Road / Gravel / CX Chainring
Article number: | 024-03-04 |
The updated Praxis DM-1X rings bring Narrow/Wide 1x drivetrain performance to road, gravel, and cyclocross bikes. Forged and machined from 7075-T6 aluminum then hard anodized for durability, these direct-mount rings are precisely engineered for optimal chain retention and shifting performance. With options from 36T to 50T, dial in your ideal gearing. Whether you're grinding up steep gravel climbs or railing corners on a tight 'cross course, Praxis DM-1X rings deliver versatile 1x drivetrain simplicity so you can focus on the ride.
Weight | |||||
36t | 40t | 42t | 44t | 48t | 50t |
~94g | ~100g | ~110g | ~151g | ~166g | ~171g |
Chainline | |||||
Road Cranks - 45.5 mm | Gravel Cranks - 48 mm | ||||
Recommended Rear Derailleur | |||||
Requires Clutch Type Derailleur Shimano Shadow Plus | SRAM Type 2 | Upper Chain Guide | |||||
Not compatible with Campagnolo 10 / 11 / 12 / 13 Speed chains |
___________________________: | ____________________________ |
Interface / BCD: | • 3-Bolt SRAM Style Direct Mount Cranks |
Chain Compatibility: | • 10 / 11 / 12 Speed - Shimano, KMC, SRAM (Flattop Inlcuded) |
Material: | • 7075-T6 Aluminum | Hard Blk Anodized |
Drivetrain: | • 10 / 11 / 12 Speed - Shimano, SRAM (FlatTop) | Mechanical & Electronic |
