Praxis N/W 1X Direct Mount Road / Gravel / CX Chainring
$100.00
Article number: 015-03-04
The updated Praxis DM-1X rings bring Narrow/Wide 1x drivetrain performance to road, gravel, and cyclocross bikes. Forged and machined from 7075-T6 aluminum then hard anodized for durability, these direct-mount rings are precisely engineered for optimal chain retention and shifting performance. With options from 36T to 50T, dial in your ideal gearing. Whether you're grinding up steep gravel climbs or railing corners on a tight 'cross course, Praxis DM-1X rings deliver versatile 1x drivetrain simplicity so you can focus on the ride.
Weight
36t 40t 42t 44t 48t 50t
~94g ~100g ~110g ~151g ~166g ~171g
Chainline
Road Cranks - 45.5 mm Gravel Cranks - 48 mm
Recommended Rear Derailleur
Requires Clutch Type Derailleur Shimano Shadow Plus | SRAM Type 2 | Upper Chain Guide
Not compatible with Campagnolo 10 / 11 / 12 / 13 Speed chains
