Praxis N/W Alloy 1X Direct Mount MTB Chainring
$70.00
Article number: 015-03-04
Engineered to tackle the most technical and punishing trails, the Praxis MTN DM1X chainring delivers durability and performance for enduro, downhill, and cross-country riding. Forged and machined from 7075 T6 aluminum then hard anodized for strength, this narrow/wide 1x chainring sheds mud and withstands rock strikes while providing reliable chain retention. Its narrow-wide tooth profile grips the chain without a guide. Lightweight yet burly, the MTB DM 1X keeps you charging on your choice of 10/11/12 speed drivetrains. Praxis creates industry-leading cycling components designed by riders for riders.
Select chainring based on crank and frame compatibility. We're happy to help you choose the right ring for your bike's specs.
 Chain Offset DMA DMB
  3 mm 0 mm
 Weight 30t 32t 34t 36t
  ~61g ~66g ~72g ~79g
 Crank Compatibility SRAM style 3-Bolt Direct Mount
 Chain Compatibility 10 / 11 / 12spd Compatible | Shimano / SRAM / KMC
 Material Forged / Machined | 7075-T6 Aluminum | Hard Blk Anodized
Must use a CLUTCH type rear derailleur (Shim. Shadow or SRAM Type2)
