Praxis N/W 1X 110 BCD Road / Cyclocross / Gravel Chainring
$100.00
Article number: 015-02-02
Take your road bike off-road with confidence. Praxis' new Narrow/Wide 110BCD 1X rings open up a world of possibilities. Their innovative tooth profile provides unparalleled chain retention, keeping you in gear through mud, gravel, and everything in between. Built for 10, 11, and 12 speed systems, these rings deliver seamless shifting across various component brands. Adventure awaits. Trust Praxis to get you there. Engineered for performance, driven by passion.
Install the E-ring 110BCD chainrings on the backside of your crank spider using threaded holes and M8 bolts. The e110 design mounts opposite standard chainrings for a clean look.
Weight
36t 40t 42t 44t E-Ring 44t E-Ring 44t
~62g ~66g ~72g ~88g ~96g ~102g
Recommended Rear Derailleur
Requires Clutch Type Derailleur Shimano Shadow Plus | SRAM Type 2 | Upper Chain Guide
Not compatible with Campagnolo 10 / 11 / 12 / 13 Speed chains
