Praxis M30 THRU Bottom Bracket
$45.00
Article number: 015-03-02
The Praxis Works M30 Thru Bottom Bracket provides a smooth, durable drivetrain platform for 30mm crank spindles. With a wide stance and oversized bearings, it delivers buttery spinning and impressive longevity. Pair it with Praxis LYFT, RaceFace Cinch or Rotor REX1 cranks to experience the silky friction-free feel that Praxis is known for. Forged from 7075 aluminum then CNC machined, this bottom bracket embodies our commitment to crafting high-performance cycling components that stand up to hardcore riding.
Praxis M30 threaded bottom brackets require the M30 BB Tool to be correctly installed. The T47 Internal requires the T47 I.B tool, while the press-fit versions should be installed using a good quality bearing press. Compatibility is listed below.
BB Compatibility
Fitment Weight Bracket Width
BSA 68 / 73 (English Thread) ~106g 68 / 73 mm
BB86 / 90 / 92 ~75g 86.5 / 89.5 / 92
BB30 / PF30 - 68 / 73 mm ~140g 68 / 73 mm
BB386 EVO ~104g 86.5 mm
BBRight ~130g 79 mm
T47 Internal ~126g 85.5mm
T47 External ~103g 68 / 73 mm
Crank Compatibility
Praxis Doon & Lyft / Cane Creek eeWing / THM/ Lightning Cranks
RaceFace / Easton / Rotor 3D+ / SRAM PF30/386 EVO
Bearings
30 mm Drive / 30 mm Non-Drive
2 - 6806  -  Cartridge Steel or Ceramic
Tools / Installation
T47 Internal use the T47 Tool
BSA and BB30 / PF30 use a M30 socket tool or wrench
All others use a quality bearing press
