Praxis Works designs and manufactures some of the best bottom bracket solutions on the market. The Praxis M24/GXP bottom brackets are a great option for cranksets with a 24mm/22mm stepped spindle (GXP, Praxis M24, Oval Concepts M24). High quality Enduro stainless steel sealed cartridge bearings ensure smooth operation and a long service life. The BSA version (114 grams) features aluminum cups, while the BB86/90/92 (71 grams) has cups manufactured from Delrin.
Crankset Compatibility:
Sram GXP Cranksets, Praxis M24 (with steel spindle) Cranksets, Oval Concepts M24 Cranksets. If you need to convert one of these cranks to a different BB standard than listed below, please check out the Praxis Conversion BB page.
68mm and 73mm BSA threaded road or mountain frames
Frame Compatibility BB86/90/92:
BB86 road, BB90 mountain, and BB92 mountain frames
Weight, BSA 68/73 | 114 grams |
Weight, BB86/90/92 | 71 grams |
Bearings | Enduro Stainless Steel |
Cup Material, BSA | Aluminum |
Cup Material, BB86/90/92 | Delrin |
Crankset Compatibility | Sram GXP, Praxis M24 (steel spindle), Oval Concepts M24 |
