The Lyft crankset from Praxis Cycles is the product of experienced gleaned from their aluminum crank production, combined with years of research and development toward creating a lightweight and strong carbon crankset. When equipped with Praxis' superior cold-forged Wave Tech chainring and time-tested durable bottom bracket, this is absolutely the best option for mountain bikes running 1x drivetrains.
The Lyft features Praxis M30 Thru design, with a 30mm straight aluminum spindle to fit a wide range of frames and aftermarket bottom brackets. The M30 Thru design utilizes an adjustable locking bearing preload ring on the non-drive side crank arm for simple, set-and-forget installation. Praxis' M30 Thru standard is compatible with other manufacturer's 30mm bottom brackets, but a genuine Praxis bottom bracket is highly recommended. Current supported shell standards include BSA (English-threaded), BB30, PF30, and BB90/92. An M30 installation tool set is included with both the BSA and BB30/PF30 bottom brackets. A proper bearing press (such as a headset press) is required for installing the BB90/92 bottom bracket. Praxis manufactures a gauge for checking tolerance of BB90/92 frames.
Lyft crank arms feature hollow carbon construction, mated with a precision-machined lightweight hollow aluminum spindle. To keep just about any rider happy, these cranks are available in both 170 and 175 mm lengths, with a host of chainring tooth count options in standard 49mm (DM-A) and Boost-specific 52mm (DM-B) chainlines. These Praxis Direct Mount Wave Tech chainrings are compatible with Shimano and Sram 10 and 11 speed drivetrains, as well as Sram Eagle 12 speed drivetrains. Additionally, each crankset includes a pair of rubber arm boots to protect the crank ends from those inevitable rock strikes.
Shipping: Due to restrictions from International distributors we are not allowed to ship Praxis products to addresses in the following countries:
Australia, Austria, Belgium, Canada, China, Czech Republic, Denmark, Finland, France, Germany, Italy, Japan, Liechtenstein, Luxembourg, Malaysia, Netherlands, New Zealand, Norway, Portugal, Singapore, Slovakia, Spain, South Africa, Sweden, Switzerland, UK.
Lyft cranksets include detailed installation instructions, and a digital version is available here.
Praxis Works warrants components to be free from defects in materials or workmanship for a period of 2 years after original purchase. However, there are limitations as “nothing lasts forever” so please read their Warranty page for details.
Weight (crankarms only) | 398 grams |
Crank Arms | Hollow Carbon Construction |
Spindle | Praxis M30 Thru aluminum |
Drivetrain Compatibility | Sram/Shimano; 1x10, 1x11, Eagle 1x12 |
BB Shell Compatibility | BSA, BB30, PF30, BB92 |
