Praxis Levatime II X-Kit Chainrings
$190.00
Article number: 024-04-01
Praxis introduces the cutting-edge Levatime II X-Kit, featuring a sturdy 5mm base for enhanced shift features and quicker engagement. Refined ramps and strategic placement optimize shifting, while slimmed teeth and precise machining reduce weight without sacrificing agility.
The X-Spider, stiffer and more streamlined, ensures the "fastest and snappiest" chainring experience. Improved cross-chained clearance makes it compatible with both mechanical and electronic drivetrains.
Available in various combinations, the X-Kit adheres to SRAM standards, compatible with Zayante Carbon Road (Black or Simplified), Zayante Gravel and the Praxis Doon (2Tone) cranks. Versatile across 10/11/12 speed drivetrains, it's your go-to for seamless performance.
For a budget-friendly option, the Simplified chainrings with Zayante Carbon-S cranks offer similar performance with a slightly heavier build. Upgrade your ride with Praxis's advanced chainring technology.
Fits 53t / 39t 52t / 36t 50t / 34t 48t / 32t
 Weight ~245g ~224g ~210g ~199g
Finish Options
 2Tone Black / Silver Doon Cranks
 Black Black Zayante / Gravel Cranks
 Simplified Black (Non-Milled) Zayante-S Cranks
 Interface / BCD SRAM / Praxis 3-Bolt Style | 160 BCD
 Includes Rubber Spacer for older Praxis cranks
 Chain Compatibility 10 / 11 / 12 Speed - Shimano, KMC, Campagnolo, SRAM (Flattop Inlcuded)
 Drivetrain 10 / 11 / 12 Speed - Shimano, SRAM (FlatTop), Campagnolo (Mechanical & Electronic)
