Praxis Levatime II X-Kit Chainrings
Article number: | 024-05-03 |
Availability: | In stock (6) |
Praxis introduces the cutting-edge Levatime II X-Kit, featuring a sturdy 5mm base for enhanced shift features and quicker engagement. Refined ramps and strategic placement optimize shifting, while slimmed teeth and precise machining reduce weight without sacrificing agility.
The X-Spider, stiffer and more streamlined, ensures the "fastest and snappiest" chainring experience. Improved cross-chained clearance makes it compatible with both mechanical and electronic drivetrains.
Available in various combinations, the X-Kit adheres to SRAM standards, compatible with Zayante Carbon Road (Black or Simplified), Zayante Gravel and the Praxis Doon (2Tone) cranks. Versatile across 10/11/12 speed drivetrains, it's your go-to for seamless performance.
For a budget-friendly option, the Simplified chainrings with Zayante Carbon-S cranks offer similar performance with a slightly heavier build. Upgrade your ride with Praxis's advanced chainring technology.
Fits | 53t / 39t | 52t / 36t | 50t / 34t | 48t / 32t |
Weight | ~245g | ~224g | ~210g | ~199g |
Finish Options | ||||
2Tone | Black / Silver | Doon Cranks | ||
Black | Black | Zayante / Gravel Cranks | ||
Simplified | Black (Non-Milled) | Zayante-S Cranks | ||
Interface / BCD | SRAM / Praxis 3-Bolt Style | 160 BCD | |||
Includes | Rubber Spacer for older Praxis cranks | |||
Chain Compatibility | 10 / 11 / 12 Speed - Shimano, KMC, Campagnolo, SRAM (Flattop Inlcuded) | |||
Drivetrain | 10 / 11 / 12 Speed - Shimano, SRAM (FlatTop), Campagnolo (Mechanical & Electronic) |
