Sale
This 1x chain guide from Praxis Works is made specifically for mountain bikes with High Direct front derailleur mounts, and is compatible with chainring sizes from 26-38 tooth. This chain guide is easily installed and adjusted using a 4mm hex wrench, with both a vertical height adjustment and a vertical plane rotation adjustment of the guide head. The body of this chain guide is manufactured from aluminum alloy for strength and durability, while the guide head is injection molded from high strength plastic to reduce both chain drag and chain noise. A spare guide head is included.
Weight | 36 grams |
Drivetrain Compatibility | 1x systems |
Chainring Size Compatibiltiy | 26-38 tooth |
Material | aluminum injection molded polymer stainless hardware |
