Praxis Doon Carbon Crankset
Article number: | 015 |
The Praxis Doon road crankset, with its C.R.A.F.T.(Carbon Resin Automated Filament Technology) carbon process, offers a perfect blend of lightness (342g for 172.5mm) and stiffness for peak power transfer. Compatible with 10-12 speed drivetrains across major brands, it features an M30-THRU spindle for broad compatibility. Available with 2Tone LevaTime II chainrings or as crankarm-only, it ensures precise shifting with a 147mm Q-factor and 44.5mm chainline. The Doon is a testament to Praxis' engineering excellence.
Crankarms | 165 mm | 170 mm | 172.5 mm | 175 mm |
Weight | ~337g | ~339g | ~342g | ~345g |
Chainrings | 48t / 32t | 50t / 34t | 52t / 36t | |
Weight | ~195g | ~202g | ~211g | |
Q-Factor | 147 mm | |||
Chainline | (*) 2x - 44.5 mm / 1x - 45.5 mm | |||
Drivetrain | (*) 2x / Double | 1x / Single | ||
Chainring Options | 48t / 32t - 50t / 34t - 52t / 36t | Any SRAM Style DM | ||
Bottom Bracket | Praxis M30 Thru | |||
Chain Compatibility | 10 / 11 / 12 - Shimano, KMC, Campagnolo, SRAM (Flattop Included) | |||
Spindle | M30 Thru - 30mm Spindle (Drive / Non-Drive Side) | |||
Material | Carbon Arms, Aluminum Spider & Chainrings | |||
Interface/BCD | SRAM (Praxis) 3-Bolt Style / 160 BCD | |||
(*)2x - Not Compatible with GRX Front Derailleurs |
