Praxis Works chainrings and bottom brackets have been a hit with cyclists of every discipline. Praised for their reliable performance and durability Praxis Works has become a significant player in the aftermarket component industry. Started in 2007 Praxis has garnered acclaim through their well designed products that put performance at the forefront. This philosophy has allowed them to climb the ladder to success, but with their history so richly invested in the cycling industry, this comes as no surprise.
The new Wave format for Praxis Works single chainrings is akin to the Narrow-Wide style rings that have taken the industry by storm in recent years. Wave however offers some significant advantages that should be noted. Using alternating lateral force on each chain link Wave chainrings actively retain the chain, while still allowing space to shed accumulated mud and debris. There is also less friction when compared to traditional narrow wide rings when run at less than optimal chain lines. For riders running a single speed system this is of little concern, but with ever increasing drivetrain gear counts and the introduction of wider tires, chains and chainrings are being pushed to their limits. Available in a wide range of tooth counts these rings are designed to pair with the Praxis Works Cadet mountain crank but will install on any crank with the 3-Bolt Sram style interface. There are two options available to dial in your ideal chainline, both DM-A and DM-B rings work on a Cadet crank, but when paired with another manufacturers crank care must be taken to avoid a sub optimal chainline.
Praxis now offers 38, 40, and 42 tooth count direct mount chainrings, designed for road-style direct mount cranksets (such as those from Sram).
Please select your chainring according to your crank and frame style. If you have questions please visit the Praxis Works website or contact us and we will assist you in selecting the optimal ring for your needs.
Material | |
Crank Compatibility | Praxis Direct Mount MTB Cranks Sram 3-Bolt Direct Mount |
Chain Compatibility | 10, 11 and 12 Speed, KMC, Shimano, Sram42-50 are AXS compatible |
Rear Derailleur Compatibility | Clutch Type Required Shimano Shadow Plus Sram Type 2 |
Weights | |
28 T | 54 grams |
30 T | 58 grams |
32 T | 63 grams |
34 T | 69 grams |
36 T | 76 grams |
38 T | 96 grams |
40 T | 99 grams |
42 T | 114 grams |
44 T | 151 grams |
46 T | 151 grams |
48 T | 166 grams |
50 T | 171 grams |
