Praxis OSBB Conversion Bottom Brackets
$75.00
Article number: 21-00-00
Unlock the potential of your BB30 or Pressfit 30 (PF30) frame with Praxis' conversion bottom bracket—a robust platform for your preferred cranks. Its threaded design, unique in the market, ensures a secure interface. The press-fit non-drive side and threaded drive side cup, tightened with a Shimano BB tool, create a solid friction hold, preventing any wobbling under load. This innovative design eliminates creaks associated with pressfit BBs.
OSBB
With two offerings a Praxis conversion can be used to convert your Specialized OSBB frame to either a Shimano HTII (24 mm spindle) or a M24 / GXP (24 mm / 22 mm spindle) bottom bracket.
Di2 / EPS
The conversion bottom bracket's shape accommodates nearly any wire over the BB shell in most frames. The shell holes are for weight savings, not wire routing. If used as a last resort, ensure wiring is protected from the spinning axle.
  Shimano HTII M24 / GXP
 Crank Spindle 24 mm 24 mm / 22 mm
 Bearings 2 - 2437 1 - 2437 / 1 - 2237
 OSBB 46 mm 61 mm
 Tools 16 external notches and a 44mm ID
 Weights ~103g ~104g
