Praxis Chainring Bolt Set
Article number: | 015-03-01 |
Complementing the wide variety of Praxis rings, Praxis Chainring Bolts are now available in three distinct styles.
The standard Road Double bolts work for Praxis doubles and as aftermarket replacements, with 5 anodized black aluminum pairs and subtle white logos weighing just 10g. Installation uses 5mm and 6mm Allen wrenches.
For Praxis' Sub-Compact, the bolts specifically mount 48/32 chainrings to Praxis' 110 BCD cranks. This kit has 5 male bolts which bolt into the small chainring, with white logos weighing 9g. Installation uses a 5mm Allen wrench.
The X-Ring kits include 8x M8 bolts, the bolts specifically mount to Praxis' X-Ring 160 BCD spider. Installation uses a 5mm Allen wrench.
Road Double | Sub-Compact | X-Ring Kit | |
Weight | ~10g | ~9g | ~9g |
