Praxis Bottom Bracket Replacement Parts
$2.00 - $10.00
Praxis' line of bottom brackets are built to last, but occasionally parts become damaged or lost. Luckily, Praxis makes these inexpensive parts available to get your bottom bracket back in working order.
Compatibility
Seal Kit - Shimano - Fits all Shimano HTII conversion bottom brackets, both 68 and 73mm widths, and both standard and ceramic bearing options.
Seal Kit - GXP - Fits all Sram GXP conversion bottom brackets, both 68 and 73mm widths.
Seal Kit - M30 BB30/PF30 - Fits both M30 BB30/PF30 68 and 73mm bottom brackets.
Seal Kit - M30 BB86/BB92 - Fits the M30 BB86/92 bottom bracket only.
Conversion O-Ring - Fits all conversion bottom brackets, as well as M30 BB30/PF30 68 and 73mm bottom brackets, and the M30 Thru BB30/PF30 73mm bottom bracket.
Conversion Sleeve - 68mm - Fits all BB30/PF30 68mm conversion bottom brackets and the M30 BB30/PF30 68mm bottom bracket. This sleeve is necessary to install the bottom bracket in a PF30 road frame.
Conversion Sleeve - 73mm - Fits all BB30/PF30 73mm conversion bottom brackets and the M30 BB30/PF30 73mm bottom bracket. This sleeve is necessary to install the bottom bracket in a PF30 mountain frame.
Conversion Sleeve - OSBB - Fits all BB30/PF30 68mm conversion bottom brackets and the M30 BB30/PF30 68mm bottom bracket. This sleeve is necessary to install the bottom bracket only on 61.5mm wide Specialized OSBB frames.
Road BB
Mountain BB
Size:
BB30
Size:
BB86
Size:
BB86/92
Fits:
BB30
Fits:
BB86
Fits:
PF30
