Parlee Carbon Seatpost
| Article number: | 005-01-05 |
Parlee sets themselves apart from your typical frame manufacturer by fine tuning each of their designs to represent a caliber of build worthy of even the most elite level athletes. The Parlee Carbon Seatpost is no exception, with a totally unique shape designed to skate the line between comfort and performance. Carefully crafted and fine tuned with the perfect amount of flex throughout the head and shaft, the Parlee Carbon Seatpost is perfect for riders who consistently find themselves on poorly paved roads, and want a post that will majorly dampen road vibrations. Available with either zero offset or 25mm offset, the Parlee seatpost is sure to work with any desired fit.
| Material | Carbon |
| Weight | 224 grams |
| Length | 400mm |
| Offsets | 0mm 25mm |
| Diameter | 31.6mm |
| Rail Compatibility | 7mm round 7x9 oval |
