Parlee Altum Disc
$3,999.00
Over a decade long relationship with Parlee we've had the pleasure of building up frames suited to our customers unique needs. Often times the criteria of a specific build were obviously suited to a Parlee frameset.  One of the tough choices has been in choosing a light weight road frame or a heavier aero road frame.  That's no longer a choice that needs to be made.  The Parlee Altum combines some of the unique aero properties of the Esx with the light weight road properties of the Z5i.
The Parlee Altum-R as stated by Parlee is, "the culmination of everything we’ve learned from more than a decade of handcrafting the world’s finest carbon fiber road racing bikes."  The Altum disc is simply the disc brake version of the Altum-R with unmatched climbing qualities, yet at the same time it's agile enough for crit racing, aero enough for the solos and still comfortable enough for multi-day events.
Features:
910 gram frame (ML) with 320 gram Parlee fork.
Thru axle skewers
Tire clearance for up to 28c tires.
Clip in cable guides make building and wiring the easiest it's ever been.  Compatible with standard mechanical groups or electronic groups.
Flex fit top cap system gives 3 different caps to produce different headtube lengths, 8mm, 15mm and 25mm.
Larger tubes are both lighter and stiffer, but retain the compliance they have been known for.
Frameset inclues: Frame, fork, headset, seatpost and thru axles.
Ordering:
Once an order has been placed we'll contact you to confirm frame sizing and color and provide a delivery time.  When ordering a complete bike we'll also collect build specs such as crank length, cassette size etc...  Delivery varies depending on options, usually from 1-2 weeks.
Assembly
We recommend that assembly of a high end frame set such as the Z5i be performed by an experienced professional. At Fair Wheel Bikes, we can provide helpful suggestions for component selection as well as partial assembly prior to shipment. Contact us directly for more details.
For those wishing to run a Shimano Hollowtech II crankset, a Parlee PF30 adapter specifically designed for use with their frames is available as well as other options such as Praxis conversion bb.
Altum Disc
 SS w/T
flex-fit
top cap
MM w/T
flex-fit
top cap
MLML w/T
flex-fit
top cap
LL w/T
flex-fit
top cap
XLXL w/T
flex-fit
top cap
Actual Seat Tube (C-C) 45.5 45.5 47.2 47.2 49.2 49.2 50.6 50.6 52 52
Top Tube Length
(virtual)
52.5 52.5 54.5 54.5 56 56 57.5 57.5 59.5 59.5
Head Angle 72.5 72.5 73 73 73.5 73.5 73.5 73.5 73.5 73.5
Seat Tube Angle 74 74 73.5 73.5 73 73 73 73 72.5 72.5
Chainstay Length 41 41 41 41 41 41 41 41 41 41
Bottom Bracket Drop 7 7 7 7 7 7 7 7 7 7
Fork Rake 4.3 4.3 4.3 4.3 4.3 4.3 4.3 4.3 4.3 4.3
Standover Height 75.2 75.2 76.9 76.9 78.7 78.7 80.2 80.2 82.3 82.3
Head Tube Length 13.9 16.5 15.6 18.2 17.3 19.9 18.9 21.5 21.2 23.8
Front Center 56.7 56.7 57.8 57.8 58.3 58.3 59.8 59.8 60.2 60.2
Wheelbase 96.7 96.7 97.8 97.8 98.3 98.3 99.8 99.8 100.2 100.2
Stack 551 567 569 585 587 603 602 618 623 641
Reach 367 361 376 371 381 376 391 386 399 38594
Custom Color Options
We're always happy to work with you and Parlee to get your perfect bike. This often times means custom paint. If you order a frame and want custom paint done we can work with you. Simply let us know in the order notes and we'll contact you about paint options.
Ordering a Complete Bike
If you're interested in ordering a complete Parlee Altum with Shimano, Campagnolo or SRAM this is where to start. Every bike we build, package and deliver to our customers is customized to be as versatile as you. Using the Altum as a platform we can build a bike well versed throughout varying terrain. We can maximize the aerodynamic potential to create a platform that will get you through the valleys between climbs and down descents with the sharpest of hairpins.
Below we've laid out some example builds to give you an idea of what's possible with different wheelset / groupo combinations and pricing. Using our team of full time builders — with decades of fitting, racing and industry experience between them — you can be sure to customize your next bike to exactly what you need. Contact us to get started on your project today.
GroupoDura Ace Di2Dura AceUltegra
Wheelset DT Spline R23 DT Spline R23 DT Spline R23
Handle Bars Zipp Service Course Zipp Service Course Zipp Service Course
Stem Zipp Service Course Zipp Service Course Zipp Service Course
Seatpost Parlee Recurve Carbon Parlee Recurve Carbon Parlee Recurve Carbon
Saddle Fizik Arione Fizik Arione Fizik Arione
Skewers HED HED HED
Tyres Michelin PRO4 Michelin PRO4 Michelin PRO4
Shifter / Brake Levers Shimano 9070 Shimano 9000 Shimano 6800
Brakes Shimano 9000 Direct Mount Shimano 9000 Direct Mount Shimano 6800 Direct Mount
Crankset Shimano 9000 Shimano 9000 Shimano 6800
Bottom Bracket PARLEE PF30 PARLEE PF30 PARLEE PF30
Front Der. Shimano 9070 Shimano 9000 Shimano 6800
Rear Der. Shimano 9070 Shimano 9000 Shimano 6800
Cassette Shimano 9000 Shimano 9000 Shimano 6800
Chain Shimano 9000 Shimano 9000 Shimano 6800
Handlebar Tape Lizard Skins DSP Lizard Skins DSP Lizard Skins DSP
Cables / Housing Shimano Shimano Shimano
Bottle Cages Fairwheel Carbon Fairwheel Carbon Fairwheel Carbon
Price (USD) $7,499 $5,999 $4,999
GroupoSRAM RedSRAM Force 22Campagnolo Record
Saddle Fizik Arione Kium Fizik Arione Kium Fizik Arione Kium
Skewers HED HED HED
Shifter / Brake Levers SRAM Red22 SRAM Force22 Campagnolo Record
Brakes TRP Direct Mount Brakes TRP Direct Mount Brakes TRP Direct Mount Brakes
Crankset SRAM Red22 PF30 SRAM Force22 PF30 Campagnolo Record
Bottom Bracket SRAM PF30 SRAM PF30 PARLEE Campagnolo PF30
Front Der. SRAM Red22 SRAM Force22 Campagnolo Record
Rear Der. SRAM Red22 SRAM Force22 Campagnolo Record
Cassette SRAM XG 1190 SRAM 1170 Campagnolo Record
Chain SRAM 1190 SRAM 1170 Campagnolo Record
Price (USD) $6,499 $5,299 $6,999
Substitutions may be made based on availability.
Frame Weight910 grams (M/L)
Fork Weight320 grams
MaterialParlee High Mod SL Tubing
Bottom Bracket ShellPress Fit 30, carbon
SeatpostParlee Carbon, (0 or 25 mm offset) 31.6mm
BrakesDisc
Cable RoutingInternal, Mechanical and Di2 Compatible
