(P22) DT Swiss 350 Road Rear Hub
Article number: | 019-03-01 |
Discover the reliability and simplicity of DT Swiss 350 hubs. Engineered for optimal function, they offer tool-free maintenance, making them a smart choice for cyclists. These hubs bring DT 240 features at a budget-friendly price, with easy servicing and the option for a 54-tooth ratchet system for rapid engagement.
DT hubs come with a 2-year warranty against defects, providing top-notch quality at a reasonable price. Experience the best of both worlds with DT Swiss 350 hubs.
WHEEL BUILDING
Trust a skilled wheelbuilder for DT Swiss hub wheels. Please contact us for expert service and rim/spoke advice.
Compare | ||
Straight-Pull | J-Bend | |
Weight | ~264g | ~265g |
Spoke Holes | 28 | 24 / 28 / 32 |
Axle Standard | 5 mm x 130 mm | |
Bearings | 6902 - (2) | |
Brake Interface | Rim Brake Only | |
Freehub Engagement | 18t Ratchet |
--Wheel Building Dimensions-- | ||
Flange Diameter Left | 38.5 mm | 46 mm |
Flange Diameter Right | 45.5 mm | 46 mm |
Center to Left Flange | 33.3 mm | 33.5 mm |
Center to Right Flange | 15.8 mm | 16.8 mm |
Spoke Hole Diameter | 2.5 mm | 2.6 mm |
Spoke Hole Offset L / R | 1.75 / 2.25 mm |
