(P22) DT Swiss 350 Road Front Hub
$61.50
Article number: 019-04-05
Availability: In stock (1)
Discover the perfect fusion of reliability and simplicity with the DT Swiss 350 hub. Engineered for optimal function, its plug-and-play design allows tool-free maintenance, making it a smart choice for cyclists. These hubs bring the key features of the famous DT 240 line to a more affordable price point, making premium performance accessible to budget-conscious riders. With common-sized sealed cartridge bearings and a standard spoke hole drilling pattern, they can be serviced easily by bike shops or home mechanics. Whether you need season-long gear durability or peak equipment performance, DT Swiss 350 hubs are a solid investment.
DT hubs come with a 2-year warranty against defects, providing top-notch quality at a reasonable price. Experience the best of both worlds with DT Swiss 350 hubs.
WHEEL BUILDING
  Straight-Pull J-Bend
Weight ~110g ~149g
Spoke Holes 24 20 / 24 / 28 / 32
Axle Standard 5 mm x 100 mm
Bearings Size 6902 - (2)
Brake Interface Rim Brake Only
Flange Diameter Left 26.15 mm 39 mm
Flange Diameter Right 26.15 mm 39 mm
Center to Left Flange 37 mm 37.4 mm
Center to Right Flange 37 mm 37.4 mm
Spoke Hole Diameter 2.5 mm 2.6 mm
