Mcfk Lowriser Mountain Handlebar
$215.00
With their first mountain bike handlebar, MCFK accomplishes an impressively strong lightweight carbon bar. Intricately produced with a particularly asymmetric layering structure, MCFK is able to achieve a high stability handlebar rated up to 90 kilos. Along with durability and agility, these handlebars are also notably stiff due to the oversized 31.8mm clamp diameter.
As with all carbon components we recommend the use of a carbon prep on all friction joints. When installing the handle bar make sure to use a torque wrench to follow all torque specifications. The stem face plate should be tightened to no more than 4Nm, and any shifter or brake lever no more than 2.5Nm. The MCFK bars we've stocked are not meant to be used with bar ends.
MaterialCarbon Fiber
Finishes3K Gloss, UD Matte
Clamp Diameter31.8
Widths720mm
Sweep6 degree
RiseLow Rise: 15mm
Weight Limit90kg (195 lbs)
Torque SpecsFaceplate: 4Nm
Shifter / Brake Levers: 2.5Nm
Weight
Riser UD720mm - 121g
