Mcfk Flatbar Carbon Mountain Handlebar
$215.00
The MCFK Mountain Flatbar is an incredible feat of design and engineering.  Not only are these mountain bars some of the lightest available, but they are also incredibly strong.  Using some of the most advanced carbon prepreg available (resin impregnated reinforcing fabric), along with proprietary asymmetrical layering techniques, MCFK is able to produce some of the lightest bars in the industry while simultaneously being incredibly strong.  Rigorously tested over countless miles and under astronomical test loads, the MCFK Flatbar has earned the EFBe certificate for European safety standards.  Close attention has been paid in regards to fiber orientation in order to achieve a perfect balance of comfort and stability.  In addition to being ultra-lightweight, strong, and stable, these bars are offered in a multitude of lengths and ergonomic options that suit everything from marathon and cross country to all-mountain riding.  Available in incremental lengths from 680mm to 760mm, and 6 degree, 9 degree, or 12 degree angles, there is a model to suit almost any preference.
MCFK has added an ingenious gentle sweep near the center of their 9 and 12 degree bars.  This sweep allows riders to enjoy the comfort provided by the bar angle of their choice without having to switch out stems in order to maintain their position on the bike.  As the bar angle increases, so does the sweep, equalizing positioning on the bike through their range of bar angles for a given stem length.  To ensure ample real estate for brakes, shifters, and other controls, the width of the thicker center section has been kept to a minimum.
As these bars are available in length increments to suit most preferences, these MCFK bars are not meant to be cut down.  While they suit disciplines from cross country to all-mountain, MCFK does not recommend using these bars for enduro, freeride, or downhill applications.  In addition, they are not to be used in conjunction with any bar-ends.  Installation should be done following the manufacturers guidelines and torque specs.
MaterialCarbon Fiber
FinishUD Matte
Clamp Diameter31.8
Width Options680, 720, 760mm
Sweep Options6, 9, 12 degree
RiseFlat: 6, 9 degree - 0mm
12 degree - 5mm
Weight Limit90kg (195 lbs)
Torque SpecsFaceplate: 4Nm
Shift / Brake Levers: 2.5Nm
Mountain Handlebars
UD Matte
Size:
680mm
Size:
700mm
Size:
720mm
Size:
760mm
Carbon
Diameter:
31.8mm
Style:
Mountain
